I've researched the forums for my answer but could not find one.... today I changed my stride length in the settings after determining it with several measured step counts - all well and good. But....when I changed the stride length, did Fitbit go back and change all the daily mile data that was calculated using the default stride length? Or is it just data from this point forward?
You can find out yourself easier than searching forums. Note your distance today. or on a particular walk. Change your stride length. See if that distance changed. Then set stride length back where you wanted it.
