My versa 2 has just recently stopped displaying the correct time after I sync it.
I have updated both the app & tracker, restarted it & then done a factory reset to try & see if that fixes it but still half an hour out from the correct time.
It also will connect to the wifi but won't stay connected to it.
Any ideas????
Hi Kelly,
I wish I had the answer but I don’t. The same thing has been happening to me since the update and it’s a gradual time difference that when I sync with the phone, it’ll have the correct time but within an hour, it starts to lose sync and slowly becomes earlier and earlier to about 2 hours behind. Have you found a solution yet?
Best AnswerHi Rebecca,
thanks for your reply, unfortunately I haven’t found a fix. The watch was working fine but it ran out of battery & when I finished fully charging it the time was half an hour out & won’t sync to the same time as the app. Updated both the app & watch, have shut them down & rebooted & actual did a factory reset on the watch to see if that would get it to sync properly but no success. So have hit a brick wall with it ☹️
