Versa 2 Updating issues
I am unable to update my Versa 2 through blue tooth and wireless. It goes though installation but than goes back to the screen where it tells me I am unable to update. (would I want to try the other blue tooth or wireless).
5 REPLIES 5
Hi, you are lucky it doesn't update. If your current version is working ok, there is no need to update it before checking on the forum if there are issues.
Nice to see you here, @SunsetRunner and @Guy_.
@SunsetRunner Thanks for the details shared in your post. There could be different reasons why your Versa 2 is not updating, so I recommend you to try the troubleshooting steps from this help article: Why can't I update my Fitbit device?
Hope this helps.
If my post was helpful, you can vote for it. You can also mark it as Best Answer if it was what you were looking for!
I could not get it to update.
I could not get it to update and it has an older version.
@SunsetRunner  - if the older version is working fine there is no need to update at all without knowing why you are updating and the consequences.
