10-22-2019 16:51
10-22-2019 16:51
An option to remove the leading zero (or just kill it) for the always-on digital display. That is 7 23 not 07 23. The useless zero is there 3/4 of the time and is just a waste of power.
10-22-2019 17:57 - edited 10-22-2019 18:14
Hi @Tas314 , if you want to get rid of the zero, install the Simple Clock Face developed by Fitbit. It shows, besides the time and date, your HR and steps. regards kuzibri
BTW, sorry, installed this clock face for you to see if this worked, but, although the initial images showed no zero, the zero is still there. I will have a look for you in the Third Party Clock Faces. I know a few with the option to switch the zero off.
10-22-2019 18:17
10-22-2019 18:17
10-22-2019 18:39
10-22-2019 18:39
Hi Tom, I found several Clock Faces that had the option to remove the zero, but when I activated the Always Display On Mode, despite the settings of the choosen clock, the stupid zero still reappears, so I have to advice you to post this question in the Feature Suggestions Board, which is especially created for these kind of requests. Regards kuzibri
