My Versa 2 got an update. After the update, I cannot see the digital or analog watch on always-on mode. I see the screen that shows time, step, heart rate..and after 10 sec. all the stats disappear except the time. It is so annoying. Any help?
Are you saying that your always on display doesn't work on the Versa 2? Have you checked the quick settings to make sure that AOD is enabled?
Fitbit stated that the latest update added more AOD displays and added colored ones, none of which I can find anymore.
Best AnswerMy Versa is brand new - arrived today. I've turned on "always on". If I set the display to Analog it works as it should. But the digital display (which I'd prefer) shows only the time in the bottom left hand corner with nothing else on that screen at all - it's set to show battery, active minutes and steps. As I say, that works in analog mode but not in digital mode.
