I just noticed that i had to bump up my brightness because the normal setting was too dim all the time. it is flicking randomly almost all the time. if I hit the watch face with a flashlight it light up solid but normal room brightness has it flickering all the time. I have tried rebooting it and even a factory reset. but it continues to flicker. Any ideas I looked through the forums and could not find a match to the issue.
Hello @GregLockie I'm assuming that you are referring to the Bersa display, since the Versa does not have a backlight.
Check your brightness setting it sounds like it may be set for Auto
Best Answer@Rich_Laue I do believe the AMOLED display does have a backlight built in.I am not sure what Bersa display is?
I have the display at max and it is often to dim to view. if I flip my arm up and look at it the screen flickers getting brighter and dim repeatedly, never settling on a brightness. It reminds me of a computer monitor with the back light starting to go out.
there is no auto setting. just Dim -> Normal -> Max
