05-08-2021 06:00 - last edited on 05-09-2021 20:09 by LiliyaFitbit
Anybody having problem with versa 2 holding its battery charge ?? Mines not holding it for more than a day so having to charge it practically all the time
Also stopped sending info to my phone
Its all set up properly had the watch over 12 months but this has been happening the last 2 . It’s also not lighting up on the face watch keeps going off I have to tap to get it back !
not happy this was great in the beginning but for the money not worth it if this is what happens after 12 months .
05-10-2021 05:26 - edited 03-18-2024 10:02
Hi there, @Millswatch. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2. I understand how you must be feeling. @Guy_ Thanks for helping out!
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
If the issue persists, may I know if you're syncing with and Android or iOS device? If you're using an iOS device, please verify and let me know which app version it's running. In the meantime, please try to log out of the Fitbit app then back in. Test your Versa 2's battery behavior and see whether it keeps on draining.
Best Answer05-08-2021 21:41
05-08-2021 21:41
In all probability this is a common IOS Fitbit App fault.
Try turning off Bluetooth on the phone when not needing to sync, if the battery lasts it confirms the fault.
