10-09-2025
02:36
16:16
10-09-2025
02:36
16:16
For past few days my watch is losing charge and sticks at the time it has died. Help.
10-09-2025 04:59
10-09-2025 04:59
Hi @trishmcq2u. What model Fitbit do you use? This forum is for a child's model.
Laurie | Maryland
Best Answer10-09-2025 10:07
10-09-2025 10:07
Best Answer10-09-2025 13:17
10-09-2025 13:17
Hi @trishmcq2u and welcome to the forums.
I appreciate your message, and I'm sorry to hear that you are experiencing this issue with your Versa 2 battery.
Please let me suggest you some steps:
Firstly, verify your phone's operating system: For more information, refer to Check & update your Android version or Update your iPhone or iPad.
Check if the Always On Display mode is turned off:
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Best Answer10-11-2025 18:15
10-11-2025 18:15
I also have a Versa 2. You might hard boot the watch by keeping the side button depressed until the watch turns off as indicated by the display going dark. Wait a little, perhaps 10 seconds, then turn back on by depressing the side button until the watch faces lights up. I assume that you have verified that the watch was charged to 100% before dying. Otherwise, perhaps your charger is not working.
Your watch is probably at least a couple of years old and like any lithium-ion battery the battery will wear out which is likely the problem with your Versa 2. You can replace the battery for about $30 for parts if you or someone you know is handy. The crystal on the watch is just glued in and you can use a heat gun or hair dryer to soften the glue enabling the crystal to be pulled out to get access to the battery.
Alternatively, you can buy a new Versa 2 for about $70 on eBay. I wouldn't waste my money on a Versa 2 on Amazon as they are all "refreshed" which I think means just cleaned up but with the old battery.
