08-26-2021
02:29
04:18
JuanJoFitbit
08-26-2021
02:29
04:18
JuanJoFitbit
My Versa 2 battery was on 65% this morning & suddenly drained to 3% at some point during the day. This is the 3-4 time this has happened since I purchased it in February 2021.
I generally get around 6 days on a charge.
08-30-2021 10:08
08-30-2021 10:08
I have had the same issue the last few months and it seems to be getting worse.. My fitbit used to be on around 65% by the end of the day. Now I have to charge it after my morning workout and again at some point throughout the day and it still ends around 10% of a charge. It almost makes the product completely unusable if it will not hold a charge. If I do not charge it throughout the day it will usually shut itself off around 6:00 pm. I only receive 2 types of notifications (which I shouldn't have to limit if the product works as it should), I have always had a fitbit clock face and I have the elumination dimmed and the quick view turned off. It would be really helpful if they would actually fix the problem other than recommending the same things over and over again that appear to do nothing.
08-26-2021 04:17
08-26-2021 04:17
@lshakey It's great to see you in our Fitbit Community. Regarding the battery draining issue that your Versa 2 has experienced, I'd like you to try the tips that are listed in this help article.
After this, monitor the battery's behavior and see if it doesn't drain fast.
Hope this helps.
08-26-2021 15:39
08-26-2021 15:39
I use the standard clock face that the device came set with. I have 2-3 notifications only set to my device. Set to dim etc.
08-30-2021 04:13
08-30-2021 04:13
@lshakey Thank you for getting back and trying the recommended tips. Since the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
08-30-2021 10:08
08-30-2021 10:08
08-30-2021 13:27
08-30-2021 13:27
I agree 100%. The solutions they offer over and over again are simply a bandaid fix. Clearly there is an ongoing issue. This will be the last Fitbit I purchase unfortunately.
09-06-2021 14:36
09-06-2021 14:36
I had the battery go after 18 months of use. All I was offered was a 35% discount on a new one.
amazing that a company owned by Google is treating customers so awfully.
Fitbit will not be the replacement for sure.
07-20-2022 21:31 - edited 08-06-2022 21:11
I’m sorry but the article you posted actually says to turn the watch off display to save the battery?
what’s the point of having a watch you need to turn off?
08-06-2022 13:46
08-06-2022 13:46
This does not work. I had two fitbits, and after a year and half both looses their battery efficiency. My Versa 2 is only 18 months ago. And I have to charge every night. I’ll never buy another one
08-07-2022 19:10
08-07-2022 19:10
