04-15-2021
19:02
06:28
04-15-2021
19:02
06:28
For the past 2 days, my Versa 2 isnt holding a charge. In the morning when i put it on it is at 100% and by noon, at was at 15%. Any solutions??
04-16-2021 06:30 - edited 10-25-2023 05:35
Hi there, @djdealz20. Welcome to the Community Forums.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into consideration the conditions that impact your watch's battery.
With that being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
Hope that helps.
