11-02-2020
01:25
13:44
11-02-2020
01:25
13:44
Hi i have a versa 2 less than a year old. In recent months i noticed the battery life has gone from 5 days to 2 or 3 days max. Have not changed usage in anyway. Any ideas and what is normal expectancy before you need to change a battery in a versa 2.
11-02-2020 13:46
11-02-2020 13:46
Hi there @Kdufs, welcome to the Community Forums. I'm sorry to hear that your Versa 2's battery life is not lasting as expected. Thanks for the details provided in your post, I'll be glad to help you.
Regarding your inquiry, please note that the battery on your Versa 2 is not replaceable nor interchanged. We as Fitbit do not do it or suggest to do it as it could permanently damage your watch.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Let me know how it goes.
11-02-2020 13:46
11-02-2020 13:46
11-02-2020 16:11
11-02-2020 16:11
My battery only lasts 3 days? Any suggestions?
11-03-2020 04:35
11-03-2020 04:35
Hi there @Marcrow, thanks for stopping by in the Community Forums.
I'm sorry to hear that your watch's battery is only lasting 3 days. For help on this matter, please take a look at my post above (here).
Let me know if you need further assistance.
