03-30-2021
19:27
05:51
03-30-2021
19:27
05:51
My versa 2 does not hold charge. It's brand new. I can fully charge it and just under 24 hours it's down 20%. How do you save your battery. And I'm not using it for music or anything yet!
03-31-2021 05:55 - edited 10-02-2023 05:31
Hi there, @Cicik17. Welcome to the Community Forums. Thanks for the details provided in your post and letting me know that you're not using the Music app.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, the Always-On display, and so on. While this doesn't mean that you shouldn't use them, please take into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Best Answer03-31-2021 05:55 - edited 10-02-2023 05:31
