01-11-2022
20:32
08:26
01-11-2022
20:32
08:26
Versa 2 has recently started using battery like crazy. Usually holds charge for 4 to 5 days even with a lot of activity and notifications. Now can't even get through 2 days without having to recharge. I haven't changed any settings - I even went through everything to make sure. The charger is working and charges to 100%.
Hi there, @Sshaner945 @marchand.6. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2 devices. I understand where your concern is coming from and how you must be feeling. I'll be glad to help you.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Best AnswerThe issue I have on my Versa 2 is a little strange though. It lasts okay. From a full charge, I normally see that I use around 20% of the charrge in a day which is normal. However, what's strange is the sudden drop in battery percentage at 40%. I have seen this happen multiple times. One moment, the battery is on 40% and the next I get a battery low notification and the battery is low at 25%. Really strange though. Any fix for this??
