Versa 2 battery is draining quickly
ANSWERED
My battery is not lasting. I want to change my setting so it does not Synch all the time as I read that can drain the battery. How do I do this please?
1 BEST ANSWER
Accepted Solutions
Hi there, @Quanstroms. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
1 REPLY 1
