Versa 2 battery is draining quickly
ANSWERED
The last days my versa 2 is losing the battery realy quicly. I charge my versa at night and in the morning the battery is on 100%, in 5 hours the battery is empty. This has happend now 3 times. My versa 2 is maybe 2 or 3 years old. What to do?
1 BEST ANSWER
Accepted Solutions
Hi there, @hanhov2810. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where our concern is coming from.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
3 REPLIES 3
Hope that helps.
Thank you for your tips! I dident use anything on the clock, gps or music. However last night i reconectet the fitbit to the fitbit app and restarted it. Today its has been better and i hope its not the battery, only i had to restarted.
@hanhov2810 Awesome! Thanks for the update. I'm glad to hear that your Versa 2's battery life has improved after the restart
