10-23-2023
02:34
07:03
10-23-2023
02:34
07:03
Fitbit Versa2 draining battery too quickly
Hello there, @JanetLaw. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 2.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps to improve your Versa 2 battery life!
