05-04-2021
10:47
05:09
JuanJoFitbit
05-04-2021
10:47
05:09
JuanJoFitbit
I reset and fixed my battery issue but now my display is remaining on explaining the “shortcut” button and I cannot skip the tutorial.
Moderator edit: format
05-04-2021 19:31
05-04-2021 19:31
Welcome to the Fitbit Community, @takaine12.
Thank you for the information provided.
If you haven't done it already, please restart your Fitbit Versa 2 by following these instructions.
Whether this doesn't help, I would recommend setting up your watch as a replacement device:
Hope this helps.
Best Answer05-04-2021 19:34
05-04-2021 19:34
I should have mentioned I cannot reset it as the button stopped working. That’s why it is stuck in the tutorial part.
05:08
10:47
05-05-2021
05:08
10:47
@takaine12 Thank you for getting back and providing more details about the issue. Since you mentioned that the button stopped working, try cleaning the around the button with a toothpick in order to remove any dust or moisture that may be affecting the functionality of the button.
Hope this helps.
