08-02-2023
10:22
10:30
08-02-2023
10:22
10:30
My side button is not working. And I'm stuck on the spotify screen.
Is there any way I can manually restart my fitbit?
Thanks
Hi there, @Traceysanchez. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
While reading your post I was wondering if you've tried any troubleshooting steps prior to posting here?
If you have tried removing dust or dirt by gently using a toothpick around the button with to no avail, you can try to clear debris using canned air, just hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Then, please try restarting your Versa 2 by following these steps.
