02-27-2023
07:00
07:44
02-27-2023
07:00
07:44
My Versa 2 which is only 8 months old is sadly not responding. The side button needs to be pressed between 5 and 10 times before it eventually responds and the touchscreen only responds sporadically, very disappointing for something that is only 8 months old
02-27-2023 07:49 - edited 06-16-2023 06:43
Hi there, @ShirlsB. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand how you must be feeling.
If you haven't done so yet, I recommend trying to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Once you've done that, please restart your Versa 2 by following these steps How do I restart my Fitbit device?
If you continue having issues with the touchscreen, please restart your Inspire 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
