Versa 2 button not working
ANSWERED
it doesn't work.
1 BEST ANSWER
Accepted Solutions
Hi there, @SnowySeb. Welcome to the forums. Thanks for the details provided in your post about the issue with your Versa 2.
If you haven't done so yet, I recommend trying to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Once you've done that, please restart your Versa 2 by following these steps How do I restart my Fitbit device?
If you continue having issues with the touchscreen, please restart your Inspire 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
1 REPLY 1
