12-19-2021
17:34
04:11
12-19-2021
17:34
04:11
The button stopped operating. Is there another way to back out or restart??
ugh.
12-20-2021 04:12 - edited 08-27-2023 03:55
Hi there, @FrankieAlf. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand how you must be feeling.
If you haven't done so yet, please try to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air, just hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Then, please try restarting your Versa 2 by following these steps.
Best Answer12-20-2021 02:45
12-20-2021 02:45
Hi @FrankieAlf - you can restart via the Settings, About, Shutdown function - wait 10 seconds and place on the charger to restart it and charge it.
Best Answer12-20-2021 04:12 - edited 08-27-2023 03:55
