Versa 2 button stopped working
ANSWERED
My versa 2 is about 3 years old and the button is not responsive which makes life hard when trying to set alarms or timers
1 BEST ANSWER
Accepted Solutions
Hi there, @Kuddle. Welcome on board.
If you haven't done so yet, I recommend following the tips and recommendations I provided here
As for the link not taking you to the correct page, please try this one https://myhelp.fitbit.com/s/support?language=en_US
Hope that does the trick for you!
6 REPLIES 6
Hi there, @Mum101. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from.
If you haven't done so yet, please try to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air, just hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Then, please try restarting your Versa 2 by following these steps
Hope that helps.
My Versa 2 button is unresponsive as well.  I have cleaned around the button as suggested, still no response.  Is there an external way to restart the Versa 2?  The instructions that you reference require holding the button down for a period of time. The button isn't functional.
 Stanfam
My thoughts exactly how can you restart when the button moves but that's all it's like the internal contacts are obstructed.
Get Outlook for Android<>
@Mum101 @Stanfam I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
This link takes you back to where I started searching for help with this issue.
Having the same problems with the button not responding as well as issues with it connecting to Bluetooth. Now it is stuck on a source screen and I cannot exit or restart my device.
