Versa 2 button stopped working
My button stopped. I can see and feel the button move but it will not work on my versa. I also powered it off and can’t turn it back on. Is there anything I can do?
7 REPLIES 7
My watch finally turned on but my button still will not respond
Welcome to the Fitbit Community, @LoveMailhot. I´m sorry to hear about your Versa 2 button and thank you for letting us know that your watch turned on.
Please clean around your watch´s button with alcohol and cotton or with canned air.
Keep on visiting the forums.
I am having the same problem. A week ago the button stopped working. Two days  ago, it stopped monitoring my sleep. Don’t know what’s happening and haven’t found a way to reset it. How did you turned it off?
Hi @JMRF - If swipe is working, in the watch Settings About menu you will find Shutdown and wait at least 10 seconds.
To restart put it on the charger.
Hi @LoveMailhot - try a factory reset - be warned it may kill the watch entirely.
In the watch Settings, About menu and wait at least several minutes before placing on the charger.
I have tried both and neither has worked is there anything else I should do
@LoveMailhot  - if you properly cleaned it and done those steps there is much else to do unfortunately.
If it's under warranty, 1 to 2 years depending on country law, you may be able to get it replaced where you bought it.
Welcome to the Fitbit Community, @JMRF and thank you for your advise @Guy_.
@JMRF, to restart your watch you can follow the instructions of help article: How do I restart my Fitbit device?
@LoveMailhot since cleaning the button didn't work the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
