09-01-2023
10:11
04:27
09-01-2023
10:11
04:27
Versa 2: The left button wont press in any longer. How am I able to turn the watch on now?
09-01-2023 21:07
09-02-2023 04:29
09-02-2023 04:29
Hi there, @Mresch9. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
To better assist you, please confirm that you've tried to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air, just hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
Then, please try restarting your Versa 2 by following these steps or try the second restart method provided by @Guy_.
Best Answer09-05-2023 07:47
09-05-2023 07:47
If the button doesn't work on a Versa 2 (after cleaning), then how can it be restarted?
09-05-2023 07:50
