01-24-2024
01:36
02:16
01-24-2024
01:36
02:16
Hi, my Versa 2 button stopped working.
I can only wake the screen up with touching it several times or shaking it.
I cannot use the button, so there is no possibility to set and turn on/off the alarm clock (among other things).
There is no space between the button and the watch body to use a picker or compressed air; there is only one button, so no possibility to press the left and the bottom button as suggested).
01-24-2024 02:18 - edited 01-24-2024 02:18
Hi there, @IngeHoe. Welcome to the Fitbit Community Forums. I'm sorry to hear that the button on your Versa 2 is still not working despite the steps you've tried already. I will do my best to help you with this.
To better assist you, please confirm that you've tried to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air, just hold the Versa 2 at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
Then, please try restarting your Versa 2 by following these steps.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Best Answer01-24-2024 02:28
01-24-2024 02:28
I allready tried to do these steps but it’s no solution for my problem.
