11-06-2019 10:40 - last edited on 02-13-2020 15:03 by LiliyaFitbit
is there a versa 2 case that I don't need to take off the case to charge? Also, is there a case that is easy to take off to charge? I am a klutz and want to protect my investment
Moderator edit: format
The ones on Amazon that I have found are flexible and easy to get on and off. https://www.amazon.com/Compatible-Anti-Scratch-Protective-Smartwatch-Accessories/dp/B07Y6B32F7/ref=p...
This is the one I got. It is a nice "bumper" for the screen. Also keep an eye out for the Unicorn Beetle case to come out (Amazon search it for Versa 1), I have this case for a lot of my phones and really like the quality/price.
Best AnswerHi.
Are you able to charge with the case on? All the cases I research say no. Which one did you purchase? I’m going to buy it. What an inconvenience that is. Never thought of that. Why wouldn’t they design them like that? All electronics charge with the case on. So common!
Thx 🙏🏼
Best AnswerHi @SuzieZ10 You can't charge with the case on, but it really isn't a pain to take on and off. It's a flexible plastic. I love mine. The only problem I have is that sometimes I can't swipe down on the Versa 2; it takes a few tries. I bought the one in the link above and I also purchased it for my mom who has a Versa 2. It is worth it's weight in gold because I smack my watch on so much stuff!
Best AnswerI’m sure you figured it out already but the first line you have to take out of the rubber case to charge in any stock Fitbit charger. I bought charging dock that will fit the rubber bumper. So I don’t have to take the case off to charge it the only drawback is you’re not using a stock charger anymore.
Best AnswerEZCO [3+1 Pack] Screen Protector Plus Charger Compatible with Fitbit Versa 2 (Not for Versa), Exclusive Charging Cable Cord Dock Soft TPU Case Cover Bumper for Versa 2 Watch (Can Charge with Case on) https://www.amazon.ca/dp/B081DQC6GC/ref=cm_sw_r_cp_api_i_ZqlrEbD3NHME0
Thank you! I was having the same issue. I used the glass screens for my Versa but couldn’t find one that covered properly for the versa 2. I don’t like the thin films since they always seem to come off and other “full wrap” options had air bubbles.
