03-08-2020
13:13
05:24
JuanJoFitbit
03-08-2020
13:13
05:24
JuanJoFitbit
Hey,
I have a Versa 2, which I just bought. I tried to switch the clock faces, but they won't install. It keeps giving me an error telling me the installation failed. I've tried third party and Fitbit faces. I've tried force stopping the app, tried unpairing my Fitbit, restarting my phone, restarting my Fitbit, then repairing it. I've tried deleting the app and reinstalling it. Nothing is working. I paid for a clock face and I expect to be able to use it. All I keep getting is a generic red screen with the time in white.
Moderator edit: format
03-10-2020
12:24
10:16
03-10-2020
12:24
10:16
@Psychoginger Welcome! It's great to see you around! Sorry for the delay in my reply.
Let me help you changing the clock face on your Versa 2 and thank you for troubleshooting this issue.
Which phone are you using? Is it compatible? I suggest you refresh the link between your phone and your Versa 2 by doing the following:
Let me know how it goes.
Best Answer03-11-2020 11:16
03-11-2020 11:16
I'm using a Moto Z2. The Moto Z is on the compatible list, so I don't see why this one wouldn't be. I've tried all of that and it's still not working.
Best Answer07-04-2020 05:55
07-04-2020 05:55
Nice to see they helped you once the generic restart/reinstall/reconnect go to answer didn’t work 😞
I’ve been having the same issue... can find any help... 😞
11-26-2020 23:26
11-26-2020 23:26
It's been 8 months and I still can't get help? I've tried everything that has been suggested on other threads and it's not working. I spent all that money on this thing and I can't get a custom clock face? You'd think that the updates to the device would fix this, but no.
12-23-2020 19:32
12-23-2020 19:32
Same problem. I've tried everything and nothing is working. It is beyond frustrating and fitbit mods aren't able to help.
Best Answer12-23-2020 19:37
12-23-2020 19:37
I've done everything including a factory reset. Isn't there anything fitbit can do?! Frustrating doesn't begin to cover it. I've been trying for 2 days now! The clock face I'm trying is free & worked on my regular versa, a lot of money wasted just to get more frustrated.
Best Answer12-27-2020 13:19
12-27-2020 13:19
I've just received a versa 2 for Xmas and am unable to install a new click face....this is my second try....I reset my watch the first time. Phone is compatible S9 and all updates are done.
Any other advise pls
Best Answer12-27-2020 13:50 - last edited on 01-18-2021 19:07 by LiliyaFitbit
I found it all sorted itself out about 48 hrs after registering the watch... I was then able to download the watch faces I paid for. I know it’s frustrating but worth the wait!
Kind regards,
Best Answer12-27-2020 14:02
12-27-2020 14:02
Best Answer12-28-2020 22:03
12-28-2020 22:03
Yep, same problem here. If I can't get a resolution this garbage is going back. Worst connectivity issues I have seen in an Android device since the VERY early days of Android. Even $15 junk connects more reliably and easier than this Versa 2. Glad Costco has easy returns.
Best Answer12-28-2020 22:12
12-28-2020 22:12
Best Answer12-30-2020 16:29
12-30-2020 16:29
The retailer already exchanged it once, now I'm at the point I want a refund. This is ridiculous!
Best Answer12-31-2020 11:43
12-31-2020 11:43
This is still an issue and they do nothing about it... I will just buy an Active 2 I think, Fitbit support is trash.
Best Answer01-17-2021 21:35
01-17-2021 21:35
I have a compatible phone and have done everything. Every time your app asks me "to continue installing, Some applications did not finish installing. Do I want to continue installing?" I select yes or if I select later the next error is "Unable to install. Install failed please try again later" and it just keeps repeating. I would like to use a Fitbit approved clock face and use the app without it glitches.
01-21-2021 05:50
01-21-2021 05:50
I researched how to register the device but found that it’s technically not necessary. How did you register?
Best Answer01-21-2021 05:55
01-21-2021 05:55
I’m having same issue with my brand new versa 2 with the clock faces not installing. I did all the things everyone has mentioned here except for registering the device because I can’t see how or where to do that and read that registering isn’t necessary?? Strange thing is when I first got it I was able to install the clock faces but now I can’t for some reason.
Best Answer01-21-2021 21:17
01-21-2021 21:17
I called support and they said an update was released to some back in November. I asked him when could I expect the update and they said it could be days, weeks, or months. This was Saturday. On Wednesday the update showed up. Unfortunately it resolved nothing. I still can't update my clock faces. I still have ghost steps when sitting on the couch watching a movie. I also still get an error when installing and being asked to retry.
Bummed.
02-02-2021 13:19
02-02-2021 13:19
I've tried everything too, including doing a factory reset TWICE (which actually made it worse, because then I couldn't re-download the apps I had the first time so it was even LESS useable. A smart watch that can't manage downloading apps is pointless).
I have a new router coming this week but if that doesn't fix it (and I doubt it will) I don't know what to do! I got this Versa 2 because my Charge 3 bluetooth died so I'm tired of my fitbit not working! I should've just upgraded to the Charge 4 instead.
I contacted support and all they could do was tell me to try what I already tried then say "Your fitbit shouldn't be doing that. Let me pass this on to an elite member of my team", or something like that. Still waiting to hear back.
