09-28-2019 16:38
09-28-2019 16:38
I noticed on my Versa 2 that the watch face looks larger but the viewing area is just the same as the Versa. Do I have a setting wrong?
09-29-2019 05:43
09-29-2019 05:43
Yes the whole of my display is being used. Don't confuse the bezel with display area though, it's not an edge to edge display.
09-28-2019 23:50
09-28-2019 23:50
Hi @AJanice, good to see you in the community.
The Versa 2's display is slightly larger compared to the Versa 1,to me it is quite noticeable. Have you tried changing clock faces to see if a different one fills the entire screen? It could be the case of the one you are using has not been updated to support the Versa 2?
09-29-2019 05:15
09-29-2019 05:15
09-29-2019 05:43
09-29-2019 05:43
09-29-2019 06:03
09-29-2019 06:03
12-07-2019 10:06
12-07-2019 10:06
The large bezel area appears to make the actual viewing area of the Versa 2 about the same as the Versa to me. It isn't a big issue with me, just something I noticed.
