12-02-2020
13:51
18:15
RicardoFitbit
12-02-2020
13:51
18:15
RicardoFitbit
Following a short period when my Versa2 went flat, on recharging the watch displays a time that is way behind the correct time and a date also wildly out of step with the calendar.
12-04-2020 02:43
12-04-2020 02:43
Thanks for the information. The synchronization did the trick. All is well.
Many thanks
RayF74
12-02-2020 18:15
12-02-2020 18:15
Hi @RayF74, welcome to the Community Forums.
Thanks for bringing this to our attention. Let me share with you that our Fitbit devices use your mobile device information to display the time with the syncing process, therefore, by simply syncing your Versa 2 it should display the time that’s configured on your phone.
However, this may also also be fixed by updating the time zone in your Personal Settings. For step-by-step instructions, please check our help article: How do I change the time on my Fitbit device? and let me know how it goes.
Let me know if further assistance is needed, I’ll be here.
12-04-2020 02:43
12-04-2020 02:43
Many thanks
RayF74
12-04-2020 19:55
12-04-2020 19:55
You're welcome @RayF74, your update is also appreciated.
I'm happy to know that your syncing issue was solved. Please do not hesitate to contact me back if you require further assistance in the future or if you have any additional questions for me to answer, I'll be here ready to help you out.
Thanks for being part of the Fitbit family, it was a pleasure to assist you.
12-07-2020 03:07
12-07-2020 03:07
I am having this same issue. Syncing did not do the trick, nor did the time zone toggle (already on) off to back on. Other ideas?
12-07-2020 17:12
12-07-2020 17:12
Welcome aboard @Tmmiller1995, thanks for bringing this to my attention.
To further investigate why are you still experiencing this issue with your Versa 2, can you please let me know which phone are you using? When was the first time you experienced this situation and how many times since then? Is your mobile device's timezone setting in Automatic rather than Manual? If so, please change this specific setting to Manual and then sync your Fitbit device, let me know if this solves the issue.
Looking forward to your reply.
12-12-2020 10:15
12-12-2020 10:15
the stnc did fix; date is crrect, not time; has correct time zone
12-13-2020 17:43
12-13-2020 17:43
Hi @toups, welcome aboard.
Thanks for your post and for reaching me out. Before we can move on, can you please let me know which phone are you using? Also, which Fitbit device? Can you please confirm if you already tried the troubleshooting steps that were shared on this thread?
I'll be waiting for your reply.
02-05-2021 07:20
02-05-2021 07:20
Hi. I have been having the same issues. I did the sync and it fixed the time but not the date. I have a versa 2 syncing to an iPhone 11 Pro.
02-05-2021 16:06
02-05-2021 16:06
Welcome aboard @anna.sewell.
Thanks for trying some steps before posting over here. Can you please try the steps that are specified on: How do I change the time on my Fitbit device? and let me know if the issue persists?
02-05-2021 16:29
02-05-2021 16:29
02-05-2021 16:36
02-05-2021 16:36
Your reply is appreciated @anna.sewell.
Thanks for taking the time to share the steps you took to solve your issue, such information may be helpful for other users that are experiencing the same. Please do not hesitate to reach me out if further assistance is needed, I'll be here in the Community Forums helping our Fitbit users.
It was a pleasure to help you.
03-03-2021 21:50
03-03-2021 21:50
I have tried to sync my versa 2 numerous times and I still can't get my date and time to match my phone
06-22-2023 18:30
06-22-2023 18:30
Versa 2 displaying wrong date and time
From my Versa 2 Fitbit device, going into ‘clock’ display then back out did the trick! I had tried all of the previous suggestions, including changing time zones, deleting my app & adding it, shutting down my iPhone 12 (and my watch). Nothing worked, but going in and out of the clock setting from my watch worked! 😊
06-22-2023 20:57
06-22-2023 20:57
Hi @Mel2917 - thanks for reporting what worked, it can help others.
Generally if a clock face has an issue, going to settings and back to the clock face restarts it and may clear the fault, also restarting the watch does the same thing or even changing clock face can be the final resolution.
06-25-2023 21:59
06-25-2023 21:59
How do you restart the watch? Nothing seems to be working for me.
06-25-2023 22:05
06-25-2023 22:13 - edited 06-25-2023 22:32
Well, I wasn't getting good answers. No one even suggested restarting the watch. But that didn't work, either.
07-14-2023 06:31
07-14-2023 06:31
Hi it says it’s synced to my phone and it’s on the right time but on my watch it’s the complete wrong date and time
