Welcome to the community forums @AnkitaPorwal, @Gardengirlee.
@AnkitaPorwal Thank you for letting us know the difficulty that you are experiencing regarding the device. Also, thank you for trying to fix it on your own.
Please confirm you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?
If the restart doesn't work and the Versa 2 does not vibrate while trying to perform the restart, I'd suggest making sure you've also tried all steps provided below:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
@Gardengirlee please confirm that you have tried the restart method as indicated here: How do I restart my Fitbit device?
Please make sure that the power source, the charging contacts on your device and the charging pins on your charging adapter are OK. If your device won't charge, this might be helpful: Why isn't my Fitbit device's battery charging?
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone
