07-04-2021 09:41 - last edited on 07-05-2021 15:59 by LiliyaFitbit
I have re-intalled the app and re-started my phone many times and it only works the first time, later it doesn't work. I have many weeks like this.
Moderator edit: subject for clarity and format
07-04-2021 09:43
07-04-2021 09:43
Mine had quit, I did the updates, started working for about a week and now I'm having the same problem. I bought this watch for Text notifications!
07-05-2021 15:58 - edited 07-05-2021 16:00
Welcome to the Fitbit Community, @Monicacb. It’s good to see you in the community, @lmboothroses.
Thanks for the details shared in your post and for already trying to resolve the issue. @Monicacb I appreciate providing a screenshot. I understand how you are feeling about this situation and if you're using Android devices, I recommend doing the following on your phones:
1. Turn off background restrictions or limitations:
- Go to Apps & Notifications > Fitbit app.
- Tap Background restrictions or Background limits to turn off the setting.
2. Turn off battery limitations:
- Go to Apps > Fitbit app > Advanced > Battery > Battery optimization.
- Change the view to All apps.
- Search for the Fitbit app and choose Not optimized.
For more tips about using the Fitbit app on an Android phone, see What should I know about using the Fitbit app on my Android phone?
For complete troubleshooting tips to resolve the issue with notifications, see Why are notifications delayed or missing?
Hope this helps.
