04-18-2021
05:59
07:35
04-18-2021
05:59
07:35
My versa 2 has a white static screen, I can't see anything or do anything. Any ideas? It's just over 2 years old
04-19-2021 07:36
04-19-2021 07:36
Hi there, @AVslider07. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
Please restart your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Best Answer04-19-2021 07:52
04-19-2021 07:52
Best Answer04-19-2021 10:54 - edited 04-19-2021 10:55
@AVslider07 You're welcome!
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer01-09-2022 06:03
01-09-2022 06:03
If you're beyond your Versa 2 warranty, then you may want to try this as it fixed the same common issue. With at least a half charge remaining on the device, place your Fit Bit in the freezer for at least one hour. This will cause the battery to cease operating the device. Pull from the freezer, push power button and you will get a dead battery sign. Allow the device to warm to room temp. From there it should operate normally. If not, then may need to repeat the process 1-2 times. My Versa 2 has worked perfectly after the second freezing method was completed. No problems since.
01-04-2023 17:56
01-04-2023 17:56
I actually tried this. After I tried restarting multiple times, as well as changing the clock face. Neither worked. I put it in the freezer for roughly an hour and it has worked ever since.
Thank you for the advice.
