06-20-2021
09:54
20:47
06-20-2021
09:54
20:47
I'm on my second Versa 3, this current unit being the replacement from warranty coverage, and here we go again: the microphone has stopped working.
I diagnosed it by accepting a phone call on my Versa 3 as well as attempting, multiple times, to ask the Google Assistant something: the caller couldn't hear anything I said, and the Google Assistant reads "Go ahead, I'm listening..."
Has anyone else experienced this microphone failure on their Versa 3? It's strange: it was working fine (I use it frequently for the Google Assistant) and then suddenly it just stops working. There was no trauma to the Versa 3: no extreme temperature exposure, not even submersion in water (which it's supposed to be able to handle anyway), and it just quit.
06-27-2021 17:43
06-27-2021 17:43
Check the settings on the Versa 3, is the microphone turned on @MisterShark
Settings - Vibration & Audio - Microphone.
08-23-2021 17:11
08-23-2021 17:11
My Versa 3 also won't respond to Alexa or Google Assistant. I don't think the mic is working. I tried all the suggestions in this forum but no luck so far. Yes, settings have the mic turned on. Yes, I removed the Alexa account and re-added it. Yes I tried using Google instead. Versa just doesn't respond.
08-24-2021 07:16
08-24-2021 07:16
I'm not sure what all the things that have been tried are.
Have you turned of your Versa 3? This is a hardware restart, not just a simple software restart.
Have you contacted Support?
10-07-2022 12:37
10-07-2022 12:37
Aaaaand now the replacement Versa 3's microphone quit.
This has got to be some kind of hardware component weakness. And note: I'm gentle with my electronics. This thing hasn't been in the water but a handful of times, and doesn't have a scratch to be found anywhere.
It's out of warranty, so the best that Fitbit would do for me is offer a 35% off discount code on a replacement Fitbit. But there are a few catches: can't use it on the newest Fitbits (Sense 2 and Versa 4) and I'm guessing that includes the new Pixel Watch.
Currently on Fitbit's online store, the Versa 3 is not available: only the old Versa 2 and the can't-use-this-discount-code-on Versa 4.
01-04-2023 16:34
01-04-2023 16:34
I had my watch replaced because the original one wouldn't turn on anymore or charge. And now the replacement after having it. I guess 5 months my microphone is speaker or not working. I did a factory reset on the watch. I uninstalled and reinstalled the app. Make sure the microphones turned on in the watch. Skip sure versa 3 is connected.
Best Answer01-04-2023 17:36
01-04-2023 17:36
I gave up and sold my Versa 3 on eBay, with a full disclosure that the microphone was not functional.
I bought the Pixel Watch. So far so good, but time will tell.
