11-18-2020
17:18
04:07
JuanJoFitbit
11-18-2020
17:18
04:07
JuanJoFitbit
When I woke up this morning my Versa 2 had lots of flickering lines on the screen. I let the battery run down and did a reset and it worked fine for about half an hour before the flickering lines came back. The watch is less than a year old.
11-19-2020 04:06
11-19-2020 04:06
Hi @DannyDot, welcome to our Fitbit Community. I'm sorry to hear that the screen of your Versa 2 has flickering lines on the screen. I totally understand how you feel about this and I appreciate the time spent trying to get this issue resolved before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
After this, try setting up your watch from scratch and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer11-19-2020 04:32
11-19-2020 04:32
Best Answer11-19-2020 07:55
11-19-2020 07:55
This is a common issue and @Fitbit won't fix it. So frustrating when it's a BIG issue!
