05-23-2020
01:02
06:04
JuanJoFitbit
05-23-2020
01:02
06:04
JuanJoFitbit
I have factory reset my Fitbit versa 2 and the senor on the back will not turn on. Normally it flashes a green light. I have uninstalled the app and reinstalled. Please help.
07-01-2020
06:03
18:16
07-01-2020
06:03
18:16
Hi @Taylor_93, welcome to our Fitbit Community! Regarding the heart rate sensor issue that your Versa 2 has experienced, I appreciate the time spent trying to get this issue resolved before contacting our forums.
I was able to get in touch with our Support team and was told that they assisted you via email. I'm glad to hear that a solution was provided and you are back on track with a replacement unit.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Best Answer07-01-2020 06:19
07-01-2020 06:19
Hi!
Can you please share what the resolution was? I have been having the same issue for days.
Best Answer07-01-2020 07:17
07-01-2020 07:17
I have had the same problem for about a week as well
Best Answer07-01-2020 07:32
07-01-2020 07:32
Please share solution. I have the same problem.
Best Answer07-01-2020 10:59
07-01-2020 10:59
Best Answer07-01-2020 11:10
07-01-2020 11:10
Best Answer07-01-2020 13:19
07-01-2020 13:19
Best Answer07-01-2020 13:20
07-01-2020 13:20
Best Answer07-01-2020 19:48
07-01-2020 19:48
I'm having the same problem. the watch is fully charged but I can'g get it to track my sleep or heart beat.
What do I do to fix it?
thank you.
Carol
Best Answer07-01-2020 19:52
07-01-2020 19:52
Taylor, does it work now?
Best Answer07-07-2020 09:07 - edited 11-16-2023 02:46
Hi everyone.
I'm sorry to hear that you're having issues with the heart rate sensor on your Versa smartwatches. Thank you for all the steps you've done so far to get the issue fixed. We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
Please note that our main purpose is to avoid negative experiences to our customers, we're always willing to help and provide troubleshooting steps. Then, if the tracker is deemed defective we review eligibility using the one year warranty option.
Additionally, our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can.
I understand that the outcome of your case with our Support Team is not fulfilling your expectations, but keep in mind that every case is completely different from the other's, thanks for taking the time to share your experiences and feedback. For more information about the outcome of your case, please get in touch with our them again and also, you can check our warranty policies here for a better understanding of the information that they provided to you.
On the other hand, if you've exhausted all troubleshooting steps to fix the heart rate monitor on your watch and you're still in touch with our Support Team, I'd suggest to keep your conversation with them as they know what's the next step to try after everything you have done.
Hi there @TheChiefsWife. Thanks for the details provided in your post, I'll be glad to help you with the heart rate sensor on your Versa 2.
If you haven't done so yet, please try the following steps (even if you have tried some of them already, let's perform them in the order shown):
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device?
I'm looking forward to your response, keep me posted.
Best Answer07-07-2020 13:40
07-07-2020 13:40
How long is it under warranty?
Best Answer06-17-2022 22:59
06-17-2022 22:59
This is my 3rd FitBit... Followed the instructions... and the Heart Rate still does not work... Stopped working after I updated the FitBit... All 3 of my fitbits started having issues or went out just after the 18 month warranty... Starting to think it is intentional to make me buy another one... But I am done... The name should really be changed to **ahem**Bit... because that is what they are... Will NEVER buy another one... Apple Watch here I come... You are owned by Google... Sadly I expected better quality than this... and coincidence that all started having issues or went out around 19 months... Very Very Disappointed !!!
