06-04-2024
15:56
03:40
06-04-2024
15:56
03:40
My Fitbit started to glitch this past weekend. It goes from screen to screen with out touching it. When I try touching the screen, it is frozen. I use the timer a lot and that stopped working today. My battery is charged.i tried restarting and still glitches.
Hi @Burnapet - unfortunately those symptoms are an early onset indication of a watch fault, possibly from moisture getting in (recently or over time).
As a last resort you could try a factory reset but this isn't without risk and as you already have issues you may not be able to set it up again, especially if the screen stops working properly.
Though if still under warranty it can be replaced.
Hi there, @Burnapet. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is still acting odd. I understand your concern, I will do my best to help you!
I agree with @Guy_. Have you tried cleaning your Versa 2? If you haven't done so yet, please see How do I clean my Fitbit device?
Nevertheless, I do agree with the factory reset as our last resort. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Versa 2 and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
If nothing seems to help, as Guy_ suggested, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
