09-26-2023
08:28
09:22
09-26-2023
08:28
09:22
Versa 2 not showing correct sleep time start
09-26-2023 09:24
09-26-2023 09:24
Hi there, @tooty1. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 2.
As a first approached, I'd recommend to sync your Versa 2 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
09-26-2023 09:24
09-26-2023 09:24
