05-10-2022 12:00 - last edited on 05-10-2022 13:57 by MarreFitbit
Hello hi, versa 2 overxount steps and counts steps while in car. like 2,000 steps a lot. help? how turn down sensitive? how make stop count
05-10-2022 13:58 - edited 11-03-2023 11:55
Hi there, @Finn123. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Please note wrist trackers count steps depending on the movement of your arms. Fitbit has worked hard to make sure that our devices do not pick up false steps or activity recordings while driving. Unless you're driving in a car with a very stiff transmission or on bumpy roads, your device should not give you false readings. Also, if you place it in a surface with something vibrating or if you make hard hand movements. You can learn more about how your Fitbit tracks steps by checking the article: How accurate are Fitbit devices?
Fitbit devices have a finely-tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement—such as working or cooking—you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps. For most customers, the number of extra steps added by arm-based movement isn’t significant when compared to your overall stats. For more information, see: How does my Fitbit device calculate my daily activity?
Additionally, please confirm the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average.
Hope this helps.
Hope this helps.
