03-24-2020 11:59
03-24-2020 11:59
Since the last update my Versa 2 no longer auto recognises when I walk although it records my steps, does not record the activity when I walk unless I start and finish manually, Versa 2 loses connection several times throughout the day, I now turn my Versa 2 on and off on average 8 or 9 times a day. Is there a fix for these issues?
03-24-2020 12:17
03-24-2020 12:17
@Pepper97 Could you please specify which update? Fitbit mobile app or Versa's firmware? Also, could you please share your phone model, OS and Versa's firmware version?
Best Answer03-24-2020 12:32
03-24-2020 12:32
I believe the update was to both my watch and app, have had a few over the last couple of months.
my phone model is iPhone 6s as well as iPhone X, having the issues on both phones.
Best Answer03-24-2020 12:34
03-24-2020 12:34
@Pepper97 Could you please verify the firmware version for me? Please open Settings app on your Versa, scroll down to About and tap it. The firmware version should be the first one at the top.
Best Answer03-24-2020 13:37
03-24-2020 13:37
The version is detailed as 35.70.721
Best Answer03-24-2020 18:16
03-24-2020 18:16
@Pepper97 That's the most recent version of the firmware. Please one of these workarounds to restore connectivity and notifications:
Best Answer03-26-2020 11:34
03-26-2020 11:34
@Pepper97 did you manage to make it work? 😄
Best Answer03-26-2020 12:14
03-26-2020 12:14
I’ve rebooted the watch twice now and no change, i have been in touch with fitbit directly and advised them, hopefully they may have further suggestions to rectify the ongoing issues, thank you
Best Answer03-26-2020 12:59
03-26-2020 12:59
@Pepper97 At this point I am afraid regular reboot won't cut it. I would perform a factory reset (restoring versa to factory defaults) and I think that's what Customer Support will suggest next.
Before factory reset, make sure you have deleted versa from your phone's Bluetooth settings (not Fitbit app). To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. This will wipe all data from your tracker so it would be good if you could sync it first. If you're unable to use the screen, please try performing the factory reset using the back button:
After factory reset you will need to set up your versa again by adding a replacement device in your Fitbit mobile app. You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
