06-10-2024
08:09
07:24
ManuFitbit
06-10-2024
08:09
07:24
ManuFitbit
After my update, the clock doesn't work right and does show any data- steps, calories burned, etc. I've restarted the versa and checked all the settings and it still doesn't work. All I can use is the analog watch face as the other clock faces won't show up on the screen.
I meant doesn't show any data..
06-14-2024 07:41
06-14-2024 07:41
Welcome to the forums @Debann24.
Thank you for sharing the inquiry regarding your Versa 2 and for the attempt to fix it on your own.
Please confirm that you restarted the device as indicated: Press and hold the button for 10 seconds until you see the Fitbit logo on the screen, and then release the button.
In addition, chanche the clock face following these steps: How do I change the clock face on my Fitbit device?
Best Answer06-15-2024 05:42
06-15-2024 05:42
Yes, I did restart my device and change the clock face with no resolution of the issue.
Best Answer06-16-2024 19:23
06-16-2024 19:23
Hi @Debann24 - your watch may have a fault but try double tap on the screen and then swipe up the watch face and see if the watch is recording stats, steps, HR etc. in the Today app, if not it may have a fault.
Also you can sync with the Fitbit App and see what's being recorded.
To make sure that works see Why won't my Fitbit device sync?
You mentioned an update, what was that update doing?
