10-20-2021 09:45 - last edited on 10-20-2021 14:04 by LiliyaFitbit
My fitbit versa 2 has started to lose about 10 minutes everyday. It is okay when just freshly charged but then starts slipping. Help
10-20-2021 14:11
10-20-2021 14:11
Welcome to the Fitbit Community, @SueAnnan. It’s good to see you in the community, @ifitaintbroke.
@SueAnnan Thanks for the details shared in your post. I recommend confirming that your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app? Please also try the following in the Fitbit app: click your profile photo > App settings > toggle Automatic time zone off/on, then sync your watch.
@ifitaintbroke Thank you for sharing your experience and solution. I recommend following our complete troubleshooting tips in Why won't my Fitbit device sync?
Hope this helps.
Best Answer10-20-2021 10:10
10-20-2021 10:10
Have the same issue with my Versa. Seemed to start after the last update. The problem seems to be that it is no longer syncing to my phone. Only way I have found to fix it so far is to delete the device and readd it but having to do this every day is a PITA.
Best Answer10-20-2021 14:11
10-20-2021 14:11
Hope this helps.
