I charged my Versa 2 and when I took it off the charger the main screen no longer works. I am able to scroll to the other screens but the main screen will not turn on. I have restarted my FitBit several times and checked my screen settings. Help.
Hi @Malinda.Fouts What a Strange problem! I'd suggest you try installing a different clockface - a fitbit one - and see if that fixes it. If not, try a factory reset (settings app and scroll down to About) and then set up again. If that still doesnt fixnit yiu will need to contact Customer Support
Helen | Western Australia
This is happening on my for versa lite also. I tried to install a new Fitbit face and I get a message saying unable to install, try again later. I tried many many times.
Best AnswerThank you! Changing the clock face worked.
Best Answer@Malinda.Fouts Fantastic! Im glad it fixed it 😊
Best AnswerI searched around in the community question and answers and someone suggested a reset by holding the back button for 10 seconds. That worked for me.
Best AnswerWelcome to the Fitbit Community, @Dan2elle.
Thank you for joining the thread and sharing that you're experiencing the same issue with your watch. I understand how you are feeling and appreciate your efforts. I recommend trying the following:
Additionally, I recommend checking if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
Hope this helps.
Same here. It’s charged and syncing with my phone but the clock face is blank!
