08-13-2025
18:29
20:54
ManuFitbit
08-13-2025
18:29
20:54
ManuFitbit
Versa 2 won’t sync. Message - data not cleared. Sync and try again. How do I clear the data?
Moderator edit: clarified subject.
Good to see you for the first time in the community @Win-Sam.
Thank you for providing the details regarding this difficulty with your Versa 2.
Please, try the following steps:
Sync the device in the Fitbit app.
Check for available Firmware updates.
Charge the Versa 2: Ensure secure connection to the charging cable and that the cable is plugged into a working USB port. (computer or UL-certified wall charger).
If these steps don't work, proceed to the next step: Restart the device: How do I restart my Fitbit device?
If you are still having the issue, try this step: How do I change the clock face on my Fitbit device?
Best AnswerThanks for your response. None of the answers worked. The message I keep getting is "the data did not clear" so it starts syncing but cannot complete the sync
