02-02-2021 03:32
02-02-2021 03:32
I have read a ton of blogs on the mic on not working on the versa 2. I have done a hard reset and tryed most of the solutions suggested but nothing works .
It's not just not working with Alexa but also voice text. It's listening but nothing happens. Any solutions I may have missed??
02-02-2021 10:58
02-02-2021 10:58
Hi @SunsetRunner first thing I would ask is if the mic is turned on.
You say that it isn't working, but listening. Can you elaborate? Do you receive any error messages?
Best Answer02-02-2021 11:58
02-02-2021 11:58
Yes the mic is turned on.
When I try to use it with Alexa or reply to a text message, it will show listening on the screen but does nothing. I can select pre loaded replys, but it won't pick up anything on the mic.
