02-02-2021 02:30
02-02-2021 02:30
My versa 2 will not sync to my Galaxy S10. App is updated and still will not sync. Has not synced since the newest update last week.
02-02-2021 02:32
02-02-2021 02:32
I've also restarted both multiple times
02-02-2021 03:25
02-02-2021 03:25
There where two updates last week, the Friday update suposedly fixed the sync issue. Have you tried these steps. Especially clearing the cache.
02-02-2021 06:14
02-02-2021 06:14
I've done it all! It said my tracker needed to update but I can't update it if it won't sync. I've done everything but a factory reset on my tracker
02-02-2021 10:51
02-02-2021 10:51
I'm not sure what the everything steps you tried are.
A factory reset or removing the tracker from your account, really should not be done.
Did you simply restart, ir do a complete shutdown?
02-02-2021 11:00
02-02-2021 11:00
02-02-2021 11:22
02-02-2021 11:22
I finally got it to work after uninatalling the app, doing a factory reset on the tracker, restarting the phone and restarting from scratch like I had just gotten it out of the box. I haven't had this problem until the update from the beginning of last week was installed... since then my tracker would not sync with my app.
