08-23-2020
17:03
20:39
RicardoFitbit
08-23-2020
17:03
20:39
RicardoFitbit
Brand new Versa 2 decided to charge it straight out of the box. All I get it the fit bit diamond and then a black screen
08-24-2020
05:19
11:50
RicardoFitbit
08-24-2020
05:19
11:50
RicardoFitbit
I believe I have it, thanks for your help
Gayle
Moderator Edit: Personal info removed
08-23-2020 20:39
08-23-2020 20:39
Hi @IZ4, welcome to the Community Forums!
Thanks for your post. To better assist you with this, can you please let me know if the heart rate sensors are flashing or is your device completely unresponsive? If you haven't already done so, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know how it goes. Such article includes a restart process which can be really helpful for this situation
Looking forward to your reply.
08-24-2020
05:19
11:50
RicardoFitbit
08-24-2020
05:19
11:50
RicardoFitbit
Gayle
08-24-2020 15:40
08-24-2020 15:40
You're welcome @IZ4, thanks for your update.
I'm happy to know that your charging issue was resolved. Please do not hesitate to contact me back if you require further assistance in the future or if you have any additional questions for me to answer, I'll be here ready to help you out.
Thanks for being part of the Fitbit family, it was a pleasure to assist you.
08-26-2020 11:36
08-26-2020 11:36
Hi Ricardo.
I'm having a similar problem in my new versa 2. But I'm getting the message about not getting enough power to charge my Versa. I already tried all the solution I've found in this forum and also on the official webpage. But still my versa won't charge. When I plug my device in my computer it tries to charge but it gives the message related to lacking power to charge. When I try to charge from an outlet the versa does not detect the charger and it won't start charging at all. I already tried 3 different chargers and any of them will work to charge. Is there anything I can try ? Am I missing something?
08-26-2020 12:10
08-26-2020 12:10
Hi @Esteban.montene, thanks for your post and welcome to the Community Forums!
Thanks for the details that were shared in your post. To fix the battery issue you're currently experiencing with your Versa, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much. Let me know if the same message is shown on your Fitbit so we can move forward.
I'll be here if further assistance is needed.
08-26-2020 12:47
08-26-2020 12:47
08-26-2020 19:31
08-26-2020 19:31
You're welcome @Esteban.montene, your reply is also appreciated.
I'm sorry to know that you're still experiencing difficulties with the battery of your Versa 2, it's certainly not working as the way it was designed. That said, let me share with you that our Customer Support team was contacted on your behalf to provide you further assistance with the difficulties you're currently experiencing. Please keep an eye on your email inbox because they'll be in touch with you pretty soon.
In the meantime they contact you, let me know if you have any additional questions.
08-26-2020
20:39
11:30
RicardoFitbit
08-26-2020
20:39
11:30
RicardoFitbit
Thanks Ricardo, for your assistance, I'll wait for the email. I really like
the Versa 2 and it would be unfortunate if I cannot get a solution to my
problem. I enjoyed my Versa 2 for 1 month and suddenly it just won't
charge, this was disappointing.
Thanks again for your help.
*Esteban
02-23-2022 14:19
02-23-2022 14:19
Is there a resolution for this? My Versa 2 is doing this exact same thing. No matter where I plug it in, whether it's a UL-certified outlet or directly into a USB port on a computer or using any other charging device, I get the error that there is not enough power to charge. There's enough power to charge much more intensive devices such as my iPhone ProMax and my iPad, but not a Versa 2? That doesn't make sense. Any constructive help would be appreciated.
02-25-2022 14:29
02-25-2022 14:29
My problem was with the four brass contacts on the back of my Versa 2 being a bit degraded. In order to charge it, I have to position the watch in the charger just right on the countertop (usually sitting upright with the lower band stretched out in front). Sometimes it takes two or three positioning changes to get it to charge. I'm getting a new Fitbit...this one is two years old.
03-02-2022 20:05
03-02-2022 20:05
