11-11-2019 14:40
11-11-2019 14:40
i recently got a Versa 2 but it wont let me connect with my alexa. I have watched the tutorials of how to set it up. The problem seems to be that i dont see an Alexa tile when i click onto my device on the app. Does anyone have any idea why its not working?
11-11-2019 14:40
11-11-2019 14:40
Best Answer11-11-2019 14:45 - edited 11-11-2019 15:30
Hi @EmaLouiseD , Alexa works depends on where you living, not all countries are supported yet, certainly when you do not see the tile. See this site. Click the link and scroll to the bottom of the page and look for your country. If it's not present in the list, it will not work yet. Regards kuzibri
Best Answer11-11-2019 16:37
11-11-2019 16:37
kuzibri has replied to your other identical post.
Best Answer11-12-2019 01:43
11-12-2019 01:43
Thanks @SunsetRunner I checked that and I am in Ireland so it should connect
Best Answer11-12-2019 02:42
11-12-2019 02:42
Fixed the issue by turning on automatic location tab in advance settings
12-27-2019 13:44
12-27-2019 13:44
I had the same problem, I deleted amazon app and tried it, it worked.Then I down amazon app again and it working fine.
try this method
