11-23-2019
04:26
13:30
DavideFitbit
11-23-2019
04:26
13:30
DavideFitbit
My wife has got me the Versa 2. I have connected my phone which is the p20 pro. I am not recieving message alerts or call alerts. When tying to use alexa or spotify which are both set up. It says make sure Bluetooth is on and go into app and sync. Any help with this would be grateful as if not i will return.
Moderator edit: format
Hi @SimonTay, good to see you in the community.
Have you got all day sync and always connected toggled on? I would also suggest going into the settings app on your phone scroll down to battery (tap on it) - App launch - scroll down to the fitbit app and set the toggle to manage automatically to off - another box should pop up, make sure all of these toggles are set to on. Huawei have pretty strict battery management so it's likely that the system is killing the Fitbit app and processes when ser to automatic. Also hit the square button at the bottom on the navigation bar to bring up the app switcher, find the fitbit app (card) and swipe down on it. A padlock should then display on the fitbit card and lock it to the task manager, this should prevent the app from being cleared from memory.
Best AnswerThere are some troubleshooting steps you may wish to try in the following help article (here) under the step 2 drop down "Complete the troubleshooting steps". You may have already tried most of these though.
