02-13-2021 14:36
02-13-2021 14:36
My versa 2 said it's overheating and won't turn on.
02-13-2021 22:23
02-13-2021 22:23
Check for water condensation by looking through the little windows on the back with a magnifying glass.
If none, seems like this is quite a common issue. following the recent updates, if it was working fine before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
