I use it for bike and so on...it is conected to phone GPS...show same map, same route...But milage is different....one id 2,87...than...3,29...than 2,99...than...3,57...and I do same route...it show same map!!!! Dont get it? I uninstall app. Restarted watch...and again...so why if the map is totally same, why it shows different milage????
Its big known problem that doesn't look like its getting fixed any time soon i'm afraid. There's a big thread here:
Best AnswerThanks for link. I tried all things they recommend...nothing helps. I do same track on bike everyday...and it is just 2,6 km....and makes difference everytime!!! By more then half km it is Quite big!!!! I hope they try to do some with software...take data from maps...
Best Answer...and the Strava doesnt correct it as well...only taking the data from Fitbit! 😭😭😭😭
